alarm sounds when I use key to manually unlock door
32K views 6 replies 7 participants last post by  Ddaddy
#1 ·
so my battery in the key is dead and the screw is stripped so I cannot change the battery. When I manually unlock the door the alarm goes off and it is quite obnoxious. Does anyone know why or how to stop it? thanks
#2 ·
The only way to disarm the alarm system is with the remote; manually unlocking the door only unlocks the door and doesn't shut off the alarm. Assuming the key and transponder are good, inserting into the ignition should silence the alarm. (I don't remember if you have to turn the key on or not.)
I think the only way to prevent the alarm from sounding is to not set it. How are you arming the system if the battery remote is dead?
You'll definitely want to replace the battery; you should be able to extract the screw from the back with ordinary hand tools, even if it's stripped. Be sure to replace with a good screw so you don't end up in the same situation later.
#7 ·
I know this is an old thread, but my car does indeed arm when I use the door lock button before closing the door. I don't need to use the fob to arm it. I never tried to arm it by locking it using the key in the door however.
On the flip side, using the door key does not cause the alarm to sound regardless of how I armed the system. Of course, my key fob battery is still good.
#5 ·
I know i'm late to the party but mine does the same thing no matter how i lock the doors.
#6 ·
Locking the doors using the driver side or passenger side buttons arm the alarm also, says so in the owners manual, try pushing the lock down yourself and it shouldnt arm that way
