looking to buy new rotors and wanted to know the difference between cross drilled and dimpled? which one is better? difference between them?
I have Power Stop drilled and slotted rotors on my older Pursuit. After the fact, I wish I had only gotten slotted because of what Brian mentioned. It is weakening the rotor to some extent and I am not hard on brakes. The slotted should be enough to release some gases and look cool too.Dimpled, like slotted rotors, will keep the pads clean but will not be compromised like a drilled rotor will be.
I have had many customers that have bought drilled rotors over the years, and every one have over time cracked and pieces of the rotor have come off....sometimes causing major problems.....through fenders and firewalls under extreme speeds. This is if they are cast iron like most rotors are. If they are made of billet steel like Wilwood that is a different thing. They have shown to be very good but extremely expensive etc.
This has not happened to dimpled and slotted rotors as they are not compromised by the drilling. For most street applications, the dimpled would be a better fit for your car!:bigthumb:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
