Just like the title says, I tinted my tails. As with every other time I've tinted tails I kept a section of lens uncoated to remain as safe as possible (and legal too).
Even though I've got areas uncoated, I still used a light coating to give it a dark red look, not completely blacked out like most people do. I used 3 light coats of VHT, and then layed down a bunch of clear. The 3rd brake light is blacked out like the normal coating you see on cars (I did this a few days ago as a test run). That lens is covered with 4-5 heavy coats (I don't remember, but it's black). Prior to tinting the tails it was as bright as the untouched tailight LED's (which is noticeably darker than the untouched brake light LED's). I should have taken a picture but didn't think about it at the time.
Instead of removing the lenses from the car, like I normally do, I decided to try doing them on it (hence the test run with the 3rd light). I taped everything off, threw a blanket over the car to catch any over-spray then worked as normal. Light scuff, spray, clear, wet sand, polish, wax. Worked very well actually. If you've got a garage, so you don't have to worry about weather, pollen, dust etc. this is probably the way to go.
The areas uncoated are in the shape of a C and reverse C, plus the reverse lights. The shape is such that it covers both horizontal lines of the brake lights. This is nearly the entire brake light (I want people to see me stopping). The vertical line covers a portion of reflector, and tail light. I wasn't as concerned with having a large portion of the tail light uncovered, as the entire racetrack is still showing through the VHT. I still wanted to keep a portion bright as stock, and I also needed to find a way to tie in an area of untouched reflector. This strip does both well.
I also considered running the line a bit lower making a 7 (and reverse 7) type shape rather than a C to utilize more vertical portion of the tail light but then I couldn't tie in the lower horizontal line of the brake light. The C also looked better with the uncoated reverse light than the 7 did too.
So anyway, just to show off several hours of work, here's a quick look of the finished product and prep. I don't have any night, or good day shots yet. I just finished polishing them today, and actually might do a bit more. I'm pretty happy with the results, but still need to figure out how to polish inside the letters on the Dodge emblem across the back, since my buffer had little to no affect on in the center of the D and O.
Until I get better shots, here it is.
