I currently own a 2016 Charger SXT RWD and want to make it faster and I was wondering what I can add to give it some more oomf.
As an owner of two Chargers with the V-6 (one is now in the wrecking yard), I can say that FAST is not a way to describe a 4200 pound car with a 300 HP engine...quick, fun, sporty even, but never fast. I have modded both of mine and am perfectly happy with them, especially in light of the traffic I have to put up with in ABQ: on my commute to work I'm lucky if I get up to 45 mph more than one or twice..most of the time it is bumper-bumper at 15-20 mph and trying to avoid getting rear-ended by a moron yacking on a cell phone, so owning something like a Scat Pack would be senseless in this situation. Fortunately I only have to go in once a week now, I work from home the rest of the time.
The Pentastar V-6 is pretty well maxed out from the factory, the only things SHORT of a supercharger are a decent exhaust system (I recommend the SOLO "J" pipe system- I love mine) and the Hellcat lower airbox so you can add the tube to the front grille for cooler air. I myself put in an AFE Momentum GT intake on both my 2013 and 2016 which is sealed like the factory airbox and lets you use the Hellcat air tube, but it has a much better pipe from the airbox to the throttle body--it really juiced up the mid range power.
The better exhaust & intake will get you from 292 HP to around 310 HP (a stock Challenger V-6 has 305 HP). I had my 2013 dynoed several times, best was 314 HP using a Diablo Tuner (the average was 310), I've only had my 2016 on the rollers once (without a tune) and it made 310 HP/284 torque. The 2016 is a lot quicker due to the 8 speed transmission.
Personally, I would upgrade the brakes before you do anything, as the stock BR3 brake package is schizz: it has single piston calipers with 12.6" front rotors and super crappy 3/8" thick solid rear rotors. The easiest-cheapest upgrade is to put on the BR5 brakes from the RT which gets you 13.6" front rotors with dual piston calipers and 12.6" vented rear rotors. The ultimate inexpensive upgrade is the Police BR9 package which has 14.5" fronts and 13.8" rears, but the pieces are getting very hard to find (both of these bolt right on to your stock suspension).
