21 - 40 of 46 Posts
All the actuators for the Dodge Charger (e.g. blend door, mode door, recirculation door) are interchangeable ... they use the same part number. For a 2010 the actuator Mopar OE PN is 68299450AA. They are not that expensive from the dealership so you can purchase OE.
Reactions: ChargerPursuit
I ordered one online to replace the one I think is bad in mine. If when I am in there and decide at the time to replace more, I run to the dealership and hope they have one in stock. Headed out there right now to remove panels and the old one. Thanks for all the help. Feel bad I kind of hijacked this thread. Hope it was all relevant enough to o/p's issues.
I have the silencer panel off. Looking with a bright flashlight, I see the two actuators way over by the side of the center console. Can these actually be replaced without removing center console??? Even with my skinny arms??? I guess so because the instructions say nothing about removing center stack, and others have done it, but wow, they are waaayyyy back there!
That's what I was saying in post 15.. LOL..
I believe it was an 8mm socket on a 1/4" drive with a little 1" or 1.5" extension on it and it is the rear one of the two for the "mode" door.
An "offset" adapter might help, but I dunno.. It is tight in there though.
Griz
Griz
I definitely read that and was thinking I was ok with my skinny arms. Granted, I only looked for a minute or two so far, but it looks more than tight. It looks out of sight and blocked out but other stuff, and too far away. I have to take another look. Thanks for the tips!
2nd look: I feel like I'm going to have to be looking up at it. Sure would be easier with driver's seat out and laying down with my legs toward the back seat. I am not sure how I'm going to do this. I'm not super tall at 5'10", but I have to figure out a way to have my head down on floorboard looking up at the underside of dash.
I'm sorry to keep dragging this on. I squeezed under there again today with a bright flashlight, and it looks to me the screws are the plastic thumb screws? Like maybe I need needle nose pliers to remove them? The head is black, and looks to be plastic and not anything I can use a screwdriver on. I don't know if all the 05-10 LX's used the same fasteners for these, but the new actuator did not come with new fasteners and I don't want to destroy anything. My next step (hopefully someone here knows though) will be to parts department at dealership to see if they have listing for the screws/fasteners so I can see the head. The next time I have to do this, it'll be so much quicker! Thanks.
This guy replaced his driver side actuator by removing the dash bezel. You don't need to do this to replace the actuator but it helps with the video to show the actuator replacement. Maybe this will help?
I did contort myself under there yesterday. I found two of them. One I needed to remove the plate (three screws) that's between the actuator itself and the HVAC box in order to access the two screws that hold the actuator to that plate (wire harnesses and other things attached are in the way). Below that actuator is another one which is just held by two screws holding it and they are accessible. So this is why I had some confusion when reading the FSM which stated simply remove three screws holding actuator. I was trying to find three screws, when it's actually held by two screws. The plate between it and the box is held by three and the bottom by two.
I called the dealership again today, and they told me my car should have a total of three, but can't tell by diagram where they are. Not sure what third one does. Single zone climate control. I know one would be for temperature and one for controlling where air flow is directed, but what would third be for? And I didn't see a third one, but then it's hard to see around in there. I'm laying on my back, with my lower back on the door jamb, and my legs hanging out door, and my head resting on floorboard looking up. Going to try and find third one on my next day off.
Just trying to help anyone who is going to be doing this soon. I'll watch the video (thanks). Don't know if it's different for the next gen ('11 and up).
There are 3 total actuator motors for the single zone climate control. The first one is the 'blend door' actuator that controls flow for heat and AC. The second one is the 'mode door' actuator that directs the airflow through the various channels (defrost, floor, vent, etc.). The third one is the 'recirculation door' actuator that switches between outside air flow and inside recirculation air flow.
I'm sorry if I come across thick, lol, but I'm still not sure if this diagram refers to single zone, dual zone, or both. I hope this will be my last question. Are all three actuators on single zone on driver's side? Or, is one on passenger side by blower, or is that just with dual zone? I'm replacing all three of mine now while I'm at it. Again, sorry if I'm just being thick.
On the single zone (MTC) there are two doors on the diver's side (blend door [3] and mode door [7]) and one on the passenger side (recirculation door [2]). The diagram is for the dual zone (ATC) and shows the additional blend door [3] on the passenger side.
Thanks Ddaddy! Now I can stop with all the questions! I have the two removed from the driver's side. Heading to dealership tomorrow to buy two more new ones (I have one new one I got on internet when I didn't plan on replacing all of them now). I already checked and they have them in stock. More pricey than on internet, but I want them now. Thanks again for all your help.
Larry
I have all three new actuators now. I found how to remove glove box using "Search" so I can replace the third one too. Hoping to get them all in today. Thanks again Ddaddy for all the help! I'm learning the LX's slowly but surely.
I did finally get all three done on my day off Thursday. The one by blower motor was so simple. Ten minutes and I was done with that one. The other two took me hours and aggravation! But I'm glad I did all three now even though just one was messing up. I figured it was just a matter of a short time before the others did too. Now I could do the job in probably less than half the time. The first time is a not so fun learning experience.
Thanks all!
21 - 40 of 46 Posts
