Adjust headlight beam position?
39K views 6 replies 5 participants last post by  Rhill1124
#1 ·
Ever since the body shop fixed my car and replaced the passenger headlight it seems that my headlights are not aligned / positioned properly. Youtube doesn't seem to have anything on the Charger so I'm at a loss on how to adjust this myself? Would I be better off just going to the dealer to have them do it? I'm still under warranty.
#2 ·
Whatcha mean "not aligned"? There is only UP & DOWN adjustment on these cars, unless there's a hidden Horizontal adjust I haven't seen yet?
But UP & DOWN should take a.... (damn! been too long since I've done this!) Phillips or Torx bit (maybe a T-20?) and the adjustment hole for headlight has arrows and U & D.
If it's a horizontal adjustment, they either didn't get the assembly bolted in correctly...? Or, the sheetmetal the assembly bolts to is bent/warped?
Or, worse case, the reflector inside the light isn't "snapped" into place? Could also be the bulb itself not seated in the cavity correctly...?
#3 ·
Thank you for the reply. The passenger headlight beam is point too low or the driver headlight beam is pointed too high...or both. This sounds like something I should take to the dealer to resolve? :bigthumb:
#6 ·
I realize this is an old thread but still a relevant subject. Bought my 300S new in 2020 - both headlamps (standard halogen projectors) were too high, with the passenger side being slightly higher. 300 went to the dealer this past week for its 3rd annual service - 'headlamp adjustment' was on the short 'laundry list'. Drove last night for the first time since the first service visit.
Driver's side appears to be correct, while the passenger side is obviously too low. Passenger side also appears to be too far toward the driver's side, but there is no horizontal adjustment from what I can tell, only vertical adjustment. Attempting to find the adjustment procedure.
My 2020 300S 5.7 Alloy Edition.
#7 ·
It’s just a long Phillips Head screwdriver.
You’ll see a hole in the black plastic cover near the front of the engine bay, it has arrows with + and a -, + means up and - means down. Beneath that hole you should see something that looks like a little funnel. Your screwdriver goes through the hole and into the funnel, you should be able to figure it out from there.
Oh, Welcome to the forums.
