This morning I changed out my stock t-stat with a Motorad 4128. At the same time I did the 11-14-16 fuse pull (which I have done many times before). When I restarted my car, my engine light came on and stayed on. I drove the car to a local Autozone so they could scan the code(s), and here is what turned up:
-PO 700......"The PCM has received a signal to turn on the "malfunction indicator lamp" from the transmission control system."
-UO 100.....no code in Autozone reference.
Now, once the codes were read and the car restarted, the CEL light cleared and did not come back on....Any feedback on this?
Finally, the T-stat I installed is a 180 degree stat, but my car temp peaked at 199 degrees after 20 minutes of driving.....is that normal when outside temps are in the mid-50s? My stock t-stat usually kept the temps at about 210-212 degrees....
