My 2012 charger rt began running hot yesterday. Coolant boiled in the reservoir. Never fully overheated fortunately. Since the reservoir was full I thought the thermostat might have failed and I replaced it. Today while in stop and go traffic it would get to about 3/4 of the way up the gauge and then the temp would return to normal once I'd start moving again. This would happen immediately and I was only driving about 25 miles per hour, so I'm not thinking it would be due to the air cooling the engine. When I returned home I allowed it to idle to see if the coolant would circulate and drop the temp as it did while driving. It didn't and I shut it down. But again the overflow is full. Why? Obviously this is my problem but I'm not sure if Ive got air in the system or if it's a water pump. I don't want to just throw parts at it without knowing what it is. To make matters worse I'm 3 hours away on vacation with limited resources. Any ideas? Thanks.
