Anyone use this?
Reduces water usage to a fraction of a conventional car wash, 1- oz ONR per 2- gallons of water to wash the entire car, ONR is an almost waterless wash that doesn’t require rinsing, its formulated with surfactants to keep dirt in suspension, avoiding surface contact; it also provides surface lubrication, thereby avoiding surface marring.
Use a Monster Fluffy micro fibre towel for washing. Take one towel and wet it with ONR mixed as per directions. Wring it out and make a single pass per clean side of the towel. You can get 4-8 passes, with the towel folded in quarters. Each pass is then done with a perfectly clean towel surface and you're never rinsing any dirt out and releasing it in to your wash or rinse water. You can do the whole car with 2-4 towels. Apply no pressure to the towel. I just glide it over the surface and only make one pass in one direction with a clean surface.
If you use the two bucket method (one fitted with a grit guard) which highly recommended with this type of product, the wash solution will stay clean enough to be reusable as a pre-soak solution or for cleaning wheel surfaces. ONR is formulated to ensure that dirt particles won’t mix with the solution but fall to the bottom of the bucket.
There in no need to rinse afterwards with ONR, but if you feel you must, please ensure that the water goes to a sewer and not a storm drain; either way the lubricating polymers in the No Rinse do a better job of protecting the finish than conventional car soap. Use in tandem with Optimum Spray Wax for a ‘just waxed’ look
If you use the two bucket method (one fitted with a grit guard) the wash solution will stay clean enough to be reusable. ONR is formulated to ensure that dirt particles won’t mix with the solution but fall to the bottom of the bucket.
