Dear fellow members,
I jacked up my 2012 srt8 charger from two sides in the rear to see if I can tighten the brake after seeing a YouTube vid of a guy doing it by removing a rubber plug inthe rear wheels.
I could not get to them without having to remove the wheels, so I quit.
However, this triggered an error code (see attached picture). This threw the Abs, traction and brake lights (yellow, yellow & red, respectively ). I tried to clear the error code with Autel scanner but to no avail. Says internal electronic failure. I never had any of these codes before. I also checked the abs fuses , all good.
It's maybe worth telling I didn't disconnect the battery while doing this, and I rotated the wheels when they were off ground to check their grip while the brakes were applied.
Your help would be appreciated
Sent from my ANE-LX2 using Tapatalk
