21 - 40 of 952 Posts
I have that newer spindles in the second pic. So if we have the same
Spindles it should fit eh?
Discussion starter · #22 · (Edited)
I had same ones on my 2013 and everything looks like it would have fit that model, but they may have changed the knuckle slightly in mid 2014 when they came out with this upgrade. I would contact Steve White Motors, their parts guys can look up your VIN and tell you if the kit they sell will fit ($800 is a lot to spend on something you are not 100% sure of). They need to look up the steering knuckle part numbers...
https://www.ebay.com/itm/15-17-Chal...y-Performance-Brake-Kit-OEM/352040463487?hash=item51f73f2c7f:g:dsYAAOSwIWVZAMn8
I’ve compared knuckle part #s and seems to fit but The only reason I haven’t asked Steve white bc they told the scar pack wheels wouldn’t fit my car and they do. I feel they’ll say the same about the brake package bc it’s for 14 and up and I have a 13.
Discussion starter · #24 ·
You can buy one BR9 caliper&bracket from a local parts store and see if it will fit. If the caliper bolts on, then get a rotor. If any of those parts don't work, you can take them back and you're not out a whole lot of money.
Thats exactly what I’m going to do. Prob get the cardone ones from rock auto since they much cheaper than OEM.
Discussion starter · #26 · (Edited)
That is where I got my calipers & rotors (see parts list in 1st post). The only problem with Rockauto is if they don't fit you have to pay the shipping to send them back..
I have Scat Pack (WRT) wheels too..freaking things are awesome!
Hmmm would advance auto or pep boys sells em? I mean I do have a friend who works at Dodge and maybe he can get a discount
Discussion starter · #28 · (Edited)
No OReilly in NJ. Didn’t even think of Napa lol
I saw that earlier. I got the rear one for free. My buddy is a boro mechanic and they didn’t use them for some reason so I got a police caliper bracket for like $50 bucks from someone on here!
Discussion starter · #34 · (Edited)
The Police here use those Raybestos wiggle slotted rotors as replacements when the originals wear out. I've seen them on Rock auto listed as raybestos and as AC Delco...the Rock catalogue is weird though..some are listed under 2015 but not 2016, some under rotors only, others under rotor& pad...anyway you have to check just about every option in their menu to find what you want.
My Power Stop AR83092XPR drilled/slotted rotors only show up under 2015- charger-5.7- brake & wheel hub-rotor-performance (same menu you find the $69 Raybestos wiggle rotors)
I like em. They look cool too lol
Have we confirmed for sure the 2011 Pursuits can not get the BR9 package installed via brackets but will need the whole knuckle as well. I understand the hub is different but is the bolting for the brackets different.
No clue. Do the route I’m doing. Go to Napa and buy the caliper and see if it bolts up and if so cool. If not return it.
Steve White confirmed the BR9 kit will fit my 13 Daytona. Sweet! Still gonna get one caliper and rotor first to confirm before buying it.
What are the PN for both the centric brake lines? I see ya have the one number.
