Yes, you do. ZF, the designer and manufacturer of your trans, recommends fluid change at 80,000-120,000km (50k-75k miles) or 8 years...whichever comes first. The shorter interval is for "severe service".Hello
Do I need to change ZF 8 speed transmission fluid , if yes on which distance
It takes ZF LifeGuard 8 fluid. MOPAR has their own re-branded version. It's pretty expensive at around $30/quart. Also, the filter is part of the actual transmission pan so you have to replace the pan as well. That alone costs a bit over $200 at Rockauto. On top of that, the process to check the fluid level is somewhat time consuming. So just in parts and fluid, you're near $500. If you're paying someone else to do it, I'd expect to pay 700-800 bucks all together.Thanks RitzRT for your professional reply , may I ask more questions
- How much it cost approximately and what is the best fluid on the market since I found different fluid brands for this gearbox
Many thanks
Agreed. Having that thermostat/valve diverting fluid back to the trans until it's hot certainly complicates things as well.Seems like a poor design. what ever happened to the dipstick check?
Here is what you need to know. We make the best fluids for these vehicles:Thanks RitzRT for your professional reply , may I ask more questions
Many thanks
I'll be touching base with you when summer gets here on this topic for both the 2015 SXT and 2013 SRT. :beerchug:Here is what you need to know. We make the best fluids for these vehicles:
https://www.chargerforums.com/forums/showthread.php?t=303257
You don't need to spend $30.00+ for the OEM ZF Fluids when you have a QuantumBlue Racing ZF 8 speed ATF that has 200 degrees hotter temperature resistance to break down and more robust friction modifiers for these units. We also provide the OEM Filtran, bolts, pipe plug and gasket for 10% over cost!
Give us a call and we can get you the correct materials.:bigthumb:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
Forum Vendor for 10 years!
So, something I've been thinking about since reading that the fluid should be changed occasionally. NOT getting into the how often or kind, etc....Agreed. Having that thermostat/valve diverting fluid back to the trans until it's hot certainly complicates things as well.
Best,
The problem is that the magnets get full of shavings in the pan and the filtran filter needs to be replaced as the inlet is very small as you have seen from the pictures.So, something I've been thinking about since reading that the fluid should be changed occasionally. NOT getting into the how often or kind, etc....
Most people do not have access to an actual lift to get the vehicle level - and off wheels - so the fluid level can be set after pan/filter replacement.
So the thought I had was getting a fitting with the correct thread and a barb on the other end. Clear vinyl hose can be attached, and interface to transmission can observed from top of car, and fluid can be filled / extracted after driving and bringing to valve open temp, and then rechecked after cool down. Outside of thread to inner opening of fitting only is a couple mm, so difference in fluid level would be insignificant. When happy about level, car up on ramps again, and if you are careful, you would only lose a little fluid during the swap.
I said AFTER changing the pan / filter.The problem is that the magnets get full of shavings in the pan and the filtran filter needs to be replaced as the inlet is very small as you have seen from the pictures.
Best to get the pan replaced after you drain the fluid and replace it with good clean ATF.
The alternative being $1,200 at a dealer when the time comes because I - and most others - don't have a lift available? Despite what FCA says about it being lifetime, there's a bunch of info out there - including from ZF - that sooner is better. Getting creative seems OK as long as it achieves the proper end result, which is in this case, a correct fill level.Why...I'm sure Jiffy Lube will have this done correctly , for $69, while I wait in waiting room...Right !
Great Stevens12!I'll be touching base with you when summer gets here on this topic for both the 2015 SXT and 2013 SRT. :beerchug:
Not sure why you said that. I was in no way suggesting that the pan / filter NOT be replaced... "......so the fluid level can be set after pan/filter replacement....."The problem is that the magnets get full of shavings in the pan and the filtran filter needs to be replaced as the inlet is very small as you have seen from the pictures....
Best to get the pan replaced after you drain the fluid and replace it with good clean ATF....
These units are not something to play with especially if there is a warranty problem and the magnets are full with the inlet clogged!...
This is a BS Scare tactic Ritz and I thought better of you than this kind of subterfuge! There has NOT been one failure of any component of any system we have ever made a fluid for PERIOD!That train is never late.
I'm not sure I'd be rolling the dice on mystery fluid for my very expensive transmission. I'd stick with ZF's fluid, Mopar equivalent, or a commercial fluid that is compatible (in writing) with LifeGuard 8.
Brian, are you willing to reimburse costs to customers who have to sue if they are denied a warranty claim on a transmission issue if they use your fluid? Or will you just have it repaired at your expense?
Best,
