1 - 4 of 4 Posts
alright went to go take my car to walmart to change the oil drove it to the front then went into the store came back out... never turned on,, it doesnt make no sound wen i put the key in to turn it on but a red light on the left comes one... the battery is fine i think cuz the lights are on and also the fob is acting up as well...
this may sound very basic, but did you check your fuses? also run a scan on it and see if you have any codes and let us know what you come up with. Also, I'm not sure the audio forum is the place for this ;)
The red light is the theft protection system. If it's on it means that the car is protecting itself from being stolen; if you're having trouble with your keyfob you might want to try your other one to see if it reacts any better. After several failed attempts, though, it needs to be unlocked by the dealer whether you have a valid key or not.
1 - 4 of 4 Posts
