I have a chance to buy 20" rims off a 2014 300C, bolt pattern is right, but the offset is +24mm, from my research my offset is 7-20mm, so will I need spacers or will these rims even work? Thanks in advance!!
Fit what? :dunno:I have a chance to buy 20" rims off a 2014 300C, bolt pattern is right, but the offset is +24mm, from my research my offset is 7-20mm, so will I need spacers or will these rims even work? Thanks in advance!!
ame off a 2014 300c Luxury series, my vehicle is an '11 Charger SE, rear wheel drive 3.6L, and they are 20X8Fit what? :dunno:
You need to say what vehicle they came from (AWD/RWD) and what vehicle you intend to put them on.
They are 20X8, im more concerned with rubbing an suspension arm, I was at a used rim store 2 weeks ago, the guy tried 3 different sets of aftermarket rims with proper bolt pattern but all rubbed on suspension armHow wide are the wheels? and what tires do you plan on using?
Awesome, thanks for the infoIf they are 20x8" OEM wheels from a RWD 300c, they should fit your 2011 without any issues. The only problem you might encounter would be if you try to mount some unusually tall tires. Stay between 28-29" diameter on your tires; the recommended size is 245/45r20.
