I have a lead on a used 2005 rt exhaust for 100$ . Wondering if it will fit my 2011 v6 se or not.
Hoping someone will know before it's gone
Love the sound description! :bigthumb:Due the the way the exhaust pulses fire, a V6 is NEVER going to have an "old school muscle car sound", only a V8 can make that sound.
The V6 has an exhaust pulse every 60 degrees of rotation, while a V8 has the pulses every 45 degrees, which is what gives it that choppy sound.
A V8 sounds like a RRRRaaaapppp, while a V6 sounds like Blaaaahhhhh. (Best way I can describe it without sound clips!!)
You have to be satisfied with only getting a deeper tone than you have, and putting on a system with that big suitcase muffler isn't going to get you anywhere near what you want. Try looking around for a Cat Back system like DynoMax, FlowMaster, Pipes, etc.
That was the system I put on my car first. It was fine on the highway, but it droned too much for me in the stop-n-go traffic I encounter on my way to and from work... it needs resonators, but the cheap ones I tried were worse than the original system.What do you think of this system ?
No, that is something straight from NASCAR for sustained high rpm, you don't really need it. They could put in an "H" pipe up front, but again, not necessary-it just helps equalize the flow so it doesn't pop so much on deceleration.Do I need to put in an x pipe ?
