1 - 9 of 9 Posts
Excuse me for not understand this. Why is it that many exhaust systems for Chargers are connected by Clamps? Is it because it's not in sections like a bolt on? Or do people really clamp them on, or do they weld them? I could think a clamp would have some sort of a leak, in both air and sound.
Using clamps is pretty common for all vehicles. Some installers even tack weld along with clamps. Clamping is much quicker, and safer for the installer and if the install didn't fit and needed adjustment, loosen the clamps. Redoing a weld has its problems.
so is asking for tack weld is a nice compromise for everyone?
Tack welded and clamped my Zoomers
i think the advantage of using clamps is so that you can easily uninstall the exhaust if you need to.
Yup. Since we have (2) half-shafts (rather then one long drive shaft), they meet together at the coulper, which is directly above the x-pipe.
Welds rust and ultimately fail......T304 stainless doesn't. Explains why there are clamps instead of welding on high end systems. Even if the clamps wear out, you just swap them out and your T304 stainless system is still good to go whereas welding it causes it to fail once the welds rust out.
Great question. I never knew a car so widely clamped, then I realized, we don't stop fussing, changing, etc... I let them weld my tips on after I took the resonators out...I was screwed. Now, when the zoomers arrive in a few days, i'll clamp and tack.
cheaper production... most domestic exhaust manufacturers use the slip in piping with clamps...
Personally, i think those kits are like connector sets / rattle boxes / exhaust leak hell...
They take a bit of tweaking to get set properly so they dont leak / rattle etc...
the difference depends on the manufacturer and the vehicle they were made for... some are perfect, some are not, its hit and miss...
i prefer exhausts with flanges, but then you have to deal with gaskets... and most aftermarket come with the paper type gaskets that are not reuseable...
When ever I get a new exhaust with flanges, I find metal gaskets before I install the kit...
1 - 9 of 9 Posts
