1 - 2 of 2 Posts
Which tail light tinting how-to is best to follow (using VHT)
I have seen a few of them around here, but which is best and easiest to follow?
Also. When doing them, you sand before, and in between each coat of paint, do you sand after the last coat and before the clearcoat? and then if i want 2-3 coats of clear, do i sand in between each of those? and finally when completing my last clear coat -coat, do i sand? or just let dry and wax?
Thanks, i just want to make sure they are done correctly so i don't have to buy a new set.
Couple of pics of mine. One coat of Niteshades. I followed the directions on the can & they came out slick, shiny, and no runs. I saw no need for the clear either. Before and after.
1 - 2 of 2 Posts
