1 - 13 of 13 Posts
If the tires aren't mounted, it's really your call. They can certainly be reused but some wheel/tire combinations MAY have leakage problems. You'll also be treated to a perpetual tire pressure warning if the sensors are not present in your new wheels.
nothing can take that off....the warning thing??? if the sensors are not there
That, I'm unsure of. Technically it would be bypassing a safety feature of the car so it's questionable. Hopefully someone with more experience regarding this will chime in.
well bed time for me....so i will check in the morning...and sorry for tripping on you toxico....were all good right???? you werent looking at the wheels to get were you?
No, man; I got a set less than two weeks ago. If I'm a d*&k in one thread, it doesn't carry over to another. :D 'S'all good.
Not to hijack, but anyone know if there is a right way or wrong way to install the sensor? My guess is there isnt, but Im heading down to put these in my new rims. Looking to avoid a mistake.
Yep..The glue side down. Make sure you buy the rebuild kit if the sensors have been on a rim fro awhile. You can get them at many parts stores. Comes with new Hex Ferrule Nut, Cap, Rubber washer & nickle valve core. You should torque the nut to about 80 inch pounds and the valve core to about 4 inch pounds.
When I got my new rims and tires they just put new sensors in for me. Might as well get everything new. I have really thin tires and mine fit fine. I have 22's with slim nittos.
Cant be any thinner than mine! :D
Its definatly worth it to me, to have them.
mine keep going off while im driving. i check my psi and its fine. not over or under so i dunno if one or two may be dead or what.
id say get new ones with the wheels....as long as they work right :)
1 - 13 of 13 Posts
