1 - 2 of 2 Posts
I am trying to decide what wheel to put on my charger. I am thinking of the Diablo FatBoy or Diablo Teardrop in 20's or 22's. Which size would look better and will these fit nicely. Also what size tires would I need to run. Thanks
Also will 9.5 wide fit all the way around
All you need to know is that 22 x 9.5 inch rims all the way around is the way to go.
You can rotate your tires this way from front to back. The staggered look is ok but
not practical if your actually driving your car more than 10,000 miles per year.
Go with 265/35/22 tires, and I would go with Nitto 420 Extreme tires they are hands
down the best looking and performing tires in my opinion.
Also make sure your offset on your rims is a 15mm offset, this allows the rims to fit
flush with the fenders. They will not stick out or be too far under the wheel well.
You want a perfectly flush rim with the fender, this gives that FAT, ProStreet look.
Good luck.
1 - 2 of 2 Posts
