1 - 20 of 22 Posts
Proud new owner of '07 R/T with the R/T Package in Brilliant Black. Have 1400 miles on her, and lovin' every second. I look forward to learning a lot from these Forums. Any OC owners out there, I could use tips and local shop info.
Welcome to the zoo! Let the modding begin!
You should join us at Beach Burger in HB the first Friday of the month. It's a regular get together of a bunch of Charger, Magnum, and 300 owners.
http://www.chargerforums.com/forums/showthread.php?t=4706
This month might be a little quiet since a bunch of people are going to SEMA but there should still be some activity.
Congrats, and welcome from Northern Cali, Modesto to be exact.
welcome from so.calif in the south bay we also have meets the second & thrid saturdays of the month 2nd sat is at ricky & ronnies on normandie & sepulveda blvd. 3rd is at angelos off the 91,and state college so come on out and join the fun maybe will see you this saturday at rickys and ronnies,, all are welcome come out join the fun,,,
helcome to the site bro. I am in San Diego along with quite a few others. Very nice Road & Track!! Black is always the fastest!
Anyone have a link to a thread regarding this nagging "Engine Code" light (the orange light that looks this (!)... ) I get at times. Its been coming on and off lately. I've tried the ACC to ON key trick, but no service codes come up, just _ _ _ _ _ then done. Any help would be appreciated.
It's your tire pressure sensor telling you your low on air.
22. Tire Pressure Monitoring Telltale Light — If Equipped
The Tire Pressure Monitoring Telltale Light will illuminate
in the instrument cluster, and an audible chime will
be activated when one or more tire pressures is low. The
Tire Pressure Monitoring Telltale Light will flash on and
off for 60 seconds when a system fault is detected. The
flash cycle will repeat every ten minutes or until the fault
condition is removed and reset. (See page 242 for more
information.)
Discussion Starter · #19 ·
information.)
Thnx Smoke, I'll check the pressure on all my tires and add air as needed.
welcome from another OC'ian! =0)
1 - 20 of 22 Posts
