i want to smoke my tail lights but is it better to tint them or spray them? and if it is to spray them how many layers of spray and clear coat should i put, if you have your tail lights smoked please post pics.
thanks
I would ask TBYDaytona40. He just did his himself and they turned out great! He also painted the tops and sides yellow to match his car. He sprayed them.
I cheated though. I had rock blockers on there, and cut the rock blockers along the contour line and just removed the top and sides before painting them, so technically I didnt spray tint them.
I'll never look at you the same.
hahahahaha
One thing that helped make it appear seamless was a little trick called pinstriping. hehehe. I bought a cheapy roll at work ($6) and applied it along the seam between the rockblocker tint and the paint. It served to better delineate the the paint from the rockblocker, which is pretty thick. It also helped cover up my not quite as straight as I wanted cutting of the rock blocker.
