1 - 12 of 12 Posts
Im getting the Spyder headlights soon so might as well switch out all the bulbs to new stronger ones.
What bulb would you recommend for high beams to be brighter?
And i was planning on wanting to get 6k or 8k hids for the low beam and fogs, do the fogs need to be a different color or can i have both the same?
Any OEM brand bulb will do. Philips, Osram.
I put the Philips hid inthe low beam and and a Led for the running light and high beam and led for the fogs. it looked good because they where all white the tube light that comes with it is not bright during the day. Had to do some modification to the spyder housing to work but they looked great
I went with AAC HOD bulbs in my charger and they worked great. Advanced Automotive Concepts.
Those look great
They're just a bit pricey I suppose. $60 for each side. $120 buys 'em all. But they definitely improve visibility and looks when they're off they emit a blue color into the low beam dish.
Here's the look when they are off.
How does that blue emit like that is it the color of the bulbs
Yes sir, they are similar to the xenon gas bulbs you can get at autozone for $16, except they won't melt into a little ball of goo from the electrical connections. They come with jumpers with voltage regulators, and the bulbs are brighter than the xenon junkers. They're High Output Dimmers.
1 - 12 of 12 Posts
