Just being curious here. I wanted to see what people's 0-60 was and what you've done to get it where it is. Don't be shy! Please share your year and specific model as well
. Thanks all!
Nice! Did you delete esp with a tuner?09 Charger R/T R&T:
-ESP delete
- Straight pipes after the cat
I can run 4.9 consistently, 4.82 is my lowest.
Nice Brian! What mods have you done to get there?I don't have the EVIC timer but 4.7 0-60 over and over again.:beerchug:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
Would love to see that and the look on your face as it happened :-D.2.1 seconds...but I was on a patch of ice at the time...:biggrinjester:
Seriously though, it's an important point. The EVIC 0-60 timer is influenced by wheel slip and can't be relied upon to be completely accurate. You need an external measurement to be sure of what your 0-60 mph performance truly is.
Nice!I thought all SRT models were equipped with some sort of performance pages?
My 07 RT's best is 5.84
-SRT Alcoas
-Mopar+Spectre intake
-DS 89 Tune for wheel size only
-Aces was the contributing factor in the only 5.84 I ran
-catchcan
The early car EVIC systems (pre-2011) use the measurements from the speedo (which has an error of +/- 3% in most cases) and don't measure actual ground velocity in any case (like the fictitious ice example I stated).Would love to see that and the look on your face as it happened :-D.
I was wondering about that myself, the most accurate way to measure?
Great info! My rt is bone stock right now(aside from the 75 cent interior mod) so I'm looking to see what everyone else has doneThe early car EVIC systems (pre-2011) use the measurements from the speedo (which has an error of +/- 3% in most cases) and don't measure actual ground velocity in any case (like the fictitious ice example I stated).
Phone based accelerometers are a little closer to reality since they calculate the g-forces involved, but they have significant errors too.
The current (2011+) cars use both the speedo and built-in accelerometers and give much more accurate measurements than either of the above examples...but still contain errors.
The best way is like they can do at a qualified track...radar guns and precise timing instruments linked by computer...done from outside the car.
Probably a loaded answer but........all my QuantumBlue fluids in engine, transmission and differential. QuantumBlue HP Gold Coolant too. Also adding ACES IV to the gasoline.Nice Brian! What mods have you done to get there?
Thanks Brian!:thumbup: have you added tuner, exhaust, cai, anything else? I know your products are qualityProbably a loaded answer but........all my QuantumBlue fluids in engine, transmission and differential. QuantumBlue HP Gold Coolant too. Also adding ACES IV to the gasoline.
Together they picked up 25 hp and 38 Ft labs of torque! This makes for faster 0 - 60 times for sure!:rocker:
Regards
Brian
BND Automotive LLC :driving:
440-821-9040
No, I have tried to do everything I can with just our products to see what could be done without changing anything else.Thanks Brian!:thumbup: have you added tuner, exhaust, cai, anything else? I know your products are quality
Great time! What mods have you done?My best is a 4.08....but that was with drag slicks at the track....Oh yeah tire slip did not occur
He uses ACES IV and all our fluids for a base of performance...I can at least answer that!Great time! What mods have you done?
Haha thanks Brian:thumbup:.I'm getting ready to remove that rust i have on my pulleys, could you send me a link to the product you have for that?He uses ACES IV and all our fluids for a base of performance...I can at least answer that!
Regards,
Brian
440-821-9040
