1 - 2 of 2 Posts
so my car hasnt been starting and i tried everything and i finnally found what i think is the problem but the only problem is i dont know what this part is called. as you can see in the image i took out the ignition and found that this part was broken. i did find another thread that the person had the same problem but that thread went totally off topic. http://www.chargerforums.com/forums/showthread.php?t=154758 what is supposed to happen is that takes the shape of the ignition switch to turn it but since its broken its just spinning in the switch that part thats broken does detach from the housing
Discussion Starter · #2 ·
heres a better image that will help locate the broken part. i guess i will try and rig it to work for now.
1 - 2 of 2 Posts
