1 - 4 of 4 Posts
I need help, I'm (hopefully) about to buy 20x9 rims for my 2014 Charger SE, and I really need to know what will fit in the front in terms of tires. Will 255's be too wide and rub? If so is 245 the maximum width I can achieve with no rub? Thank you in advance! :driving::driving::driving:
Make sure you get the correct aspect ratio; 255/45r20s will be OK, but not 255/50r20s.
Are you purchasing aftermarket or reproduction wheels? If so you'll be fine with 255/45/20 up front. If you buy 20x9 OEM SRT wheels you'll need to run a spacer 5mm to be safe but 3mm might work.
I'm using SRT wheels with a 255/45/20 up front (BFG Comp 2) and they might run a bit wider than others. I ran one summer with 3mm but rubbed a bit near full lock in reverse. Switched to 5mm this year and everything is fine.
1 - 4 of 4 Posts
