My wife hit a deer last week while on vacation. No body damage.
But I need to replace the head light and I was thinking that I would go with the projection halos. I just would like to know what you guys are buying and which ones to stay away from. Thanks in advance.
I have the Devil EyeSS from Focuz Technologies, one of our supporting vendors.
Very bright, look good.
Discussion Starter #4
I looked at the Focuz ones but they are just the rings. I need the entire light replaced. So That is a no go. I found some on ebay but I don' want then to start to sweat and get water in them.
One of the other supporting vendors had them and even had a core system setup.
I can't remember who it was off the top of my head though.
I would stay away from most anything that has a projector in it unless you can verify that it is from one of the following companies:
Stanley
Hella
Valeo
AL/Bosch
Likely none of these make a lamp with a projector for the Charger.
While th appearance may be enticing, the output will be far less than oem. Your best bet is to head over to eBay and get a set of used lamps, send them to us, we will install the rings for you-
