This just started - Rain comes through big or little and I've got a little water on the driver seat and inside door panel. Not a soaking wet but enough to see and make you jump when you sit down! I noticed this happening about a month ago and here's what I've checked or eliminated:
- Haven't had any work done or damage to anything.
- The weatherstripping looks good, no peeling, cuts, or buckling.
- The door is aligned, opens & closes just fine.
- The window rolls all the way up with no gaps and no wind noise while driving.
Anything I'm missing or maybe something so small I can't notice by the eye? - Thanks to anyone with help.
Any chance it's coming in through the sunroof? If the roof drains gets clogged, it can spill down into the headliner. I would think you'd have noticed a big stain on the headliner but sometimes you're just not looking there.
The number one cause we see of leaks such as the one you describe is a clogged or cracked sunroof drain tube as suggested above. That would be the first place I would suggest checking.
