1 - 9 of 9 Posts
There is water on the driver side floor board. It happens everytime i drive doesn't matter if ac is on or off. Any help?
Are you sure that it's water? It's more likely coolant from a leaking heater core.
Reactions: FlyersHockey
I will second that it's most likely coolant.
2021 Charger Scat Pack WB
Buy a Honda, issue solved !!!
Most likely a coolant leak. Have you been adding or need to add coolant lately?
It's clear though if you lay a paper towel on it and doesnt feel greasy at all
Do you know what coolant smells like? If you don't, you can remove your radiator cap (when cold) and see. Plus, you should probably check the coolant level anyway.
When you run the AC does water drip on ground from the bottom of the car? If it doesn’t then the drain is clogged and backing up in the evaporator. Go underneath the car and stick a bbq skewer in the drain line and unclog any debris.
Greetings Brandymh2014,
We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support via private messages.
Rob
Dodge Cares
1 - 9 of 9 Posts
