1 - 20 of 23 Posts
HERE'S YOUR LX VIN DECODER RING:
position
1 country of origin / code 2 DCx Canada
2 assembler / code b= dodge,c= chrysler
3 vehicle type / code 3= pass car
4 gvwr & pass safety / codes a= cgs, d=cgj, e=cgs
5 vehicle line/ codes 8=300c/srt8 (rwd)(lhd) 9=300C/SRT8(rwd)(rhd )
a= 300/300c/srt-8/charger (RWD)(LHD) k=300 (awd)(lhd) r= 300c/srt8 (rwd)(rhd)
6 series codes/ *=300C (BUX W/ABB) *=300C C-S48 with sales code abb
4= 300/300 c-h48/300 c-p48/ charger c-h48
5= 300 (canada) TOURING/LIMITED/PLATINUM Charger r/t d-p48
6= 300 hemi c(bux w/o abb)
7= srt8/srt8 c-x48
x= CHARGER SRT8 :happy:
7 body style codes/ 3=lx-48 8= lx-49
8 engine codes/ G= 3.5L H=5.7L HEMI R= 2.7L W=6.1L HEMI
9 check digit code/ 0
10 model year code/ 6=2006 (duh!)
11 assembly plant code/ h= brampton
12 thru 17 vehicle build sequence
there you go!
Reactions: taffy
Charger,
The 4th character (gvwr & pass safety / codes) in my VIN is "k," not "a," "d," or "e." Do you know what "k" is?
Thanks for the info.
ChargerSXT said:
Charger,
Mine too
Thanks for the info
________
Homemade soldering iron
position
7= srt8/srt8 c-x48
there you go!
I also have a "K" and the build sequence is the number of Chargers built? If so I am :happy: 132284
Should be the same as "E"/ restraint system active w/o side air bags...
At least as of 04/18/05 the last vin decoder we recieved...
the sequence number started with an arbitrary number, no way to track which actual number of your car is...they did it this way to "hide" the daytona vin #'s so they would be impossible to clone...
I also posted this info on the Protection Package thread...
I had one of the guys on the lxforum, (fnkychkn), fax me a break down of the VIN numbers for the Charger.
A few people have said that they have a "K" as the 4th character in their VIN, and according to the VIN code sheet I received:
"K" = Restraint System Advanced Multistage Front Air Bags Sales Code (CG3) With Side Air Bags Sales Code (CGS)
I'm not sure if that means there are air bags in the side bolsters of the Performance seats in the Daytona or not, but I have a Daytona on order and my VIN has a "K" as the 4th character too.
If the DCX Info people still monitor this forum maybe they can shed some light on this.
VIN Decoder
From the Tech Info section over at http://www.dodge-srt.com/
Charger SRT8 Vin Decoder
VIN DECODING INFORMATION
POSITION INTERPRETATION CODE = DESCRIPTION
1 - Country Of Origin source
1 = USA
2 = Canada
2 - Make
A = Chrysler (Hatchback)
B = Dodge (Sedan)
C = Chrysler (Sedan)
D = Dodge (Hatchback)
3 - Vehicle Type
3 = Passenger Car
4 = Multipurpose Passenger Vehicle Without Side Air Bags Sales Code (CGS) (Hatchback)
8 = Multipurpose Passenger Vehicle With Side Air Bags Sales Code (CGS) (Hatchback)
4 - Restraint System
H = Restraint System Air bags Front Next Generation Multi-Stage Sales Code (CG1) With Side Air Bags Sales Code (CGS)
J = Restraint System Air Bags Front Next Generation Multi Stage Sales Code (CG1) Without Side Air Bags Sales Code (CGS)
K = Restraint System Advanced Multistages Front Air Bags Sales Code (CG3) With Side Air Bags Sales Code (CGS)
L = Restraint System Advanced Multistage Front Air Bags Sales Code (CG3) With Side Air Bags Sales Code (CGS)
8= Multipurpose Passenger Vehicle With Side Air Bags Sales Code (CGS) (Hatchback)​
4? - Gross Vehicle Weight Rating
E = 3001- 4000 lbs. (1361- 1814) KG (Hatchback)
F = 4001- 5000 lbs. (1815 - 2267) KG (Hatchback)
5 - Vehicle Line
A = 300 / 300C / SRT-8 / Charger (RWD) (LHD)
K = 300 / 300C (AWD) (LHD)
R = 300C / SRT-8 (RWD) (RHD)
V = 300 Touring / Magnum (RWD)
Z = 300 Touring / Magnum (AWD)
6 - Series
4 = H High Line
5 = P Premium
6 = S Sport
7 = X Special
B = 4 Speed Automatic, Sales Code (DG6)
B = 4 Speed Automatic VLP, Sales Code (DGV)
E = 5 Speed Automatic, Sales Code (DGJ) 7 Body Style
7 -Body Style
3 = 4 Door Sedan Tall
7 = Hatchback Tall
8 - Engine
D = 3.0L V-6 cyl. Turbo Diesel Sales Code (EXL)
G = 3.5L V-6 cyl. High Output 24 Valve MPI Gasoline Sales Code (EGG)
H = 5.7L V-8 cyl. HEMI Multiple Displacement Gasoline Sales Code (EZB)
M = 3.0L V6 CYL 24 Valve Turbo Diesel Sales Code (EXL) (Hatchback)
R = 2.7L V6 Cyl. 24V DOHC Gasoline (MPI) Sales Code (EER)
T = 2.7L V6 CYL 24 ValveDOHC Gasoline MPI Sales Code (EER) (Hatchback)
V = 3.5l V6 CYL 24 Valve High Output Gasoline, Sales Code (EZB) (Hatchback)
W= 6.1L V8 CYL SRT HEMI Gasoline SMPI, Sales Code (ESF)
2 = 5.7L V8 CYL HEMI Multiple Displacement Gasoline Sales Code ( EZB) (Hatchback)
3 = 6.1L V8 CYL SRT HEMI Gasoline SMPI, Sales Code (ESF) (Hatchback)
9 - Check Digit
Digit 0 through 9 or X​
10 - Model Year
5 = 2005
6 = 2006
7 = 2007
8 = 2008
11 - Assembly Plant
H = Brampton Assembly​
12 - 17 - Vehicle Build Sequence
Six Digit Number Assigned By Assembly Plant​
Checking a 2007 Plum Crazy SRT-8 VIN
Ok, let's see if this actually works for my VIN 2B3LA73W37H894621
1 - 2 = Canada, yep
2 - B = Dodge Sedan, yep
3 - 3 = Passenger Car, yep
4 - L = Restraint System Advanced Multistage Front Air Bags Sales Code (CG3) With Side Air Bags Sales Code (CGS), yep
5 - A = 300 / 300C / SRT-8 / Charger (RWD) (LHD), yep
6 - 7 = X Special, yep
7 - 3 = 4 Door Sedan Tall, yep
8 - W = W= 6.1L V8 CYL SRT HEMI Gasoline SMPI, Sales Code (ESF), yep
9 - 3 = just a check digit, yep
10- 7 = 2007 model year, yep
11- H = Brampton Assembly, yep
12-17 - 894621
I'm not sure about the K in the 4th position meaning:
I don't think my Daytona has side airbags (EDIT: And My VIN DOES have a K). I don't believe they are listed on my window sticker (I'm at work so I can't confirm this.) But I do have a Factory build sheet for my VIN that someone on the forum was kind enough to provide me right in front of me. And it says:
CG3 - Advanced Multistage Front Air Bags**
Now the two asterisks is a little suspect, and they don't seem to be referenced anywhere else in the PDF. But I have always thought I didn't have side airbags since I seem to remember on the "build your own" part of the dodge web site that they were part of a safety package that included some special kind of air filtration system, none of which is mentioned in the window sticker or build sheet.
So take that FWIW...
ok I Know my car DOES NOT have side air bags and i have the K in the 4th spot....also the engine code says I have the reg 5.7 hemi... WRONG I have the 5.7 with MDS..... in fact I have the orignal window sticker so i know what's on the car...:driving:
Don't PM me, email ryanjosephevans at gmail dot com. I can get you a cool snapshot of the old Highland Park Information Management (HPIMS) screen, it looks like a build sheet. The difference is when they go down the line I believe they highlight certain codes. Then you can use a code guide, to break the codes. It's easier than the vin. :rocker:
Read it again slowly. Both 5.7L listings are with MDS, the only difference is "hatchback" and "sedan".
And the "k" in the fourth spot could refer to either one. Thats why it has two different sales codes.
ok this is gonna be kinda long but here's a breakdown of the sticker..... it has all the standard equipment PLUS package 28V.... the R/T bagdes Spoiler, perfomance seat w/ suede Daytona edition group, Painted Hemi cover,decals on hood& trunk Load leveling& height control, dual a/c heated seats, pwr seats, pwr adjustable pedals.
Electronic Conv group- I/c with Display, Temp& Compass, V.I. C. traveler/mini computer security alarm, steering wheel controls, Universal garage opener.
Sound group II- 6 Boston acoustics spkrs w/ Sub, 322w Amp, 6CD/full map Navi with GPS/ Sirius And Auto dim Rearview.
the air bags are listed as Advanced Mulitstage Front air bags. no sides SRS at all. no auto headlights, no one touch up Front window. I don't even think it has R&T pkg..... i've tried a couple of the mods on here like ESP disable with the key. Only thing that does is makes everything go off and the airbag light with come on at the same time as the chime.:confused::dunno:
Another great thread, Thanks for the info. BTW mine checks out perfectly with what was represented here by MrDolomite. Yea!
...Sound group II- 6 Boston acoustics spkrs w/ Sub, 322w Amp...
So I have the Sound Group II... where exactly is the sub and amplifier? I bought my car used about 10 days ago and haven't found these 2 items yet. Are they hidden somewhere? Thanks.
I think the amp is hidden under the dash in the '06's and the subs are in the lower area of the doors. But in later years the sub was in the trunk under the rear window shelf.
1 - 20 of 23 Posts
