1 - 11 of 11 Posts
The dealer is closed till monday and I have a seemingly annoying vibration coming from the rear of the car that you can feel it through the steering wheel when accelerating from 40-80, and only when accelerating can anyone tell me what this might be to put my mind to rest :confused: o yea i have one bald tire in the rear i dont know if that has anything to do with it. Thank you :beerchug:
I had a only sonetimes vibration and a rotation, rebalance fixed it.
Thanx man, I hope it is something as simple as a tire rebalance. I have some new nittos iam going to try to get on tommorw. Any other members want to chime in :beerchug:
I was going to say balance as well, always start w/ simplest solution:D
Rebalance is an obvious place to start. If you are getting your new Nittos on tomorrow make sure you get road-force balance and torque the lugs right and you should be good to go!
If not, let us know and we'll try to help as always.:beerchug:
Could be unbalanced or unevenly worn tires, outer tie rods going bad, or warped brake rotors...or some of each.
If you have one bald tire and one good tire on the rear, this could cause the diff to be thrown off a little due to the difference in overall diameter of the tires and possibly cause a vibration as it tries to allow the wheels to turn at different speeds, but still keep torque to them.
Discussion Starter #9
Thanks so much for the responses, unfortenetly I got my new tires mounted and balanced and the problem is still there. O well I hope all goes well at the dealer tommorow.
We have some Chevy Impalla fleet vehicles we use for work(GSA government) I've driven two and both had a high speed vibration coming from the rear.
My wifes silverado had vibration from the rear, was 2 U-Joints failing.
1 - 11 of 11 Posts
