ABS and traction 😡😡😡😤😤
my abs and traction lights came on the dashboard and diesnt come off
one mechanic told me his obd2 scanner won’t read codes because the car wouldn’t give permission ( just in case thinking why…
are there any mechanics out here in New York that knows more on this and I can come check out
charger v6
2020 grey
· Premium Member
Niscat:
Welcome to the forum. Are you within the 3/36 warranty period? If so, I'd get to your fav dealer. Those lights can be caused by a bad or failing wheel speed sensor. They are not too expensive, so you can DIY if you can drill down to the corner of the car with the problem. Usually, it's the LR or RR. When I had those lights come up on my '14 R/T, it was a rear wheel sensor.
Don
Niscat:
Don
Niscat
i am out warranty. buttt I’ve been hearing about these speed sensors . Are dealers the only ones with scanners to narrow down and pinpoint which one it is.
thanks for reply.
DRoPP
