Radio was "ghost touching" - changing stations automatically, etc. Finally convinced the dealer to replace the radio after software updates did not work. Well, the new radio seems to still have issues.
1. when remote started, the radio is coming on. My old radio would not turn on audio until the door was opened.
2. Favorites keep popping up and when pushed, there is no favorite listed there - but if you scroll through the radio there is usually a favorite on air.
Am I wrong in thinking the new radio is not functioning correctly still? The dealer has been very unhelpful and dismissive of issues.
Are you still under Warranty? If so, I would head-in to the dealer.
If not, try disconnecting the negative battery terminal for some minutes. Connect the cable back and let idle for a few minutes. Might reset everything and get working again.
If it’s under warranty I would take it to a different dealer since this one is unhelpful.
Also as stated above, try disconnecting the battery for a while to see if it resets correctly.
2019 R/T Scat Pack Plus
