I pulled my A pillar cover off and found the harness end with 11 wires running into it. Then I pulled my glove box off and I think I found the other end of the harness. When I looked behind the glove box there is a unused plug that is taped onto another bunch of wires. I am thinking that unused harness is for the u-connect brain because it is next to a vertical support that I have seen in install pics of the u-connect brain.
I am right in thinking that unused harness end is for the U connect brain?
With the factory harness installed already in the car, will I have to remove that radio or is that harness already hooked to the radio?
I would thank you for the help ahead of time.
