Hey Guys,
I'm currently designing a circuit to run accessory lighting as a turn signal. In order to make it function I need to tap into (and therefore find) two inputs: the input before the relay (which is on when the turn signal is turned on) and the output at the relay (which is the flash). Does anybody know where the relay is so I can tap before and after it?
