1 - 15 of 15 Posts
how come with the predator u can take esp off but u cant keep the asb brake system on , but when u do the turn key trick the asb stays functional. Whats the difference between the two other than that?? does predator turn it completley off and the turn key just semi off??
because they are two diffrent things, the predator puts the car into a dyno mode (a built in function)..... the turn key makes your ESP "computer" fail for having bad data so it shuts off. The NOesp mods do the same thing only in a different way.
NOesp rocks i have that in my car im running the predator on and it is very nice.
Is the ESP deactivate function on the SRT the same as the NO ESP MOD?
Do they deactivate the same things or is there something to be gained for SRT owners from the NO ESP?
the srt esp "off" (esp hold) is not all the way off, its like 85-90% off or something (regular is 60%). a no esp mod will take it 100% off.
don't everyone smoke me at the same time. What is the turn key esp off and I have the predator does it have a menu to turn the esp off
there is a HUGE post a bout turn key esp. move faster than 5 mph, turn your key for 2-5 sec and ding ding your esp will be disabled.
works in all mid 06 and up cars.
yes the predator has an esp delete, which works differently than other esp deletes (you also loose your ABS with the pred delete)
i've still noticed esp mod is quite 100%. still get some trac. control when doing donuts and it see's vehicle speed differnt
Can you explain the difference between the turn-key and the NOesp ?
Randy
Why mess with your ignition switch when you can get the Noesp mod? Cheap, easy to install, and lets you fry 'em at will, especially with a Diablo Predator tune.
Randy
turn key re-initializes the system with bad data, which fails it.
the noesp kills the sensor, giving bad data and failing it.
and neither of them harms your ignition. you cant turn your starter unless you are in park.
How do you do the turn key esp mod trick ?
Be Careful with the turn key trick
Tried the "turn key" trick the other day on my brand new R/T. Was moving at about 15 MPH on a side road, did "turn key" and ESP/BAS shut off. Great trick. However, now the MyGig/Nav System/Radio has a mind of its own. On...off...Nav doesn't work at all...everything works fine...Cannot control ANYTHING...Can control EVERYTHING.
It may just be coincidence, but computers are highly sensitive to voltage spikes. Not sure "turn key" had anything to do with this but I'm going back to the dealer for a repair and will not be doing "turn key" again while I'm running the car.
1 - 15 of 15 Posts
