So The fans are good with the tune lowering the temp for them to come on or should I lower them with the tuner more? And if so what temps should I do?
Actually the 210 and 219 is good. Remember that cooling is accomplished with 3 distinct functions in the engine.
1) Engine coolant
2) Engine Oil
3) Radiant Heat loss.
Once you have the tune and the fans are at the 210 and 219, then ACES IV will help with the reduction of heat due to better combustion of the fuel in the tune with less friction in piston rings, stems and guides.
QuantumBlue HP Gold Coolant we manufacture reduces heat faster because it doesn't have any sodium or sulfates that hold heat. 3 to 4 times faster evaporation!
We could make you a QuantumBlue HP Custom Blend that evaporates heat and yet maintains integrity for 10,000 + miles at the same time. Remember that 30% of your heat in the engine is taken away by our oil! Most people don't realize this!
We can't help on the radiant heat portion however.
These simple pour in mods will greatly assist in heat reduction, increased performance, more power and cooler running.:rocker:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
