Trunk Button Stuck/ Liner Removal
7755 Views 7 Replies 6 Participants Last post by  NJMoparOrnoCar
2
My 2018 charger has the trunk open button stuck inside the trunk. I think i might need to remove the liner inside the trunk to move/replace the button. Has anyone had a similar issue?
299230
299231
See less See more
1 - 8 of 8 Posts
Just happened to me over the weekend. If you remove the trunk liner and the silver bolts holding the tail light in, you'll be able to access the button from the backside. The bracket holding my button has rusted away which caused the button to fall out of the cutout. Trying to find the part but I've been told it can only be obtained by purchasing a whole new light bar. Any leads on this would be helpful!
My 2018 charger has the trunk open button stuck inside the trunk. I think i might need to remove the liner inside the trunk to move/replace the button. Has anyone had a similar issue? View attachment 299230 View attachment 299231
Any luck with fixing the issue just happen to my car.
My 2018 charger has the trunk open button stuck inside the trunk. I think i might need to remove the liner inside the trunk to move/replace the button. Has anyone had a similar issue? View attachment 299230 View attachment 299231 Any luck with fix? I just ran into this issue.
Any luck with fix? I just ran into the same issue.
this happened to my 2016 charger too. Bracket rusted away. I am going to make my own bracket since I can’t mind this part anywhere.
Mine also fell inside the tail light. Unable to fish it out......
So I have fallen victim of the button push in. If this rust corrosion isn't the car covered for 7 years for corrosion.? Anyone have a picture of the bracket?
1 - 8 of 8 Posts
