First I would like to say I am very new to Dodge. This is actually my first dodge.
2007 Charger R/T 5.7
I just recently changed the water pump and radiator as well as the coolant temp sensor.
A little back story on the car. I'm a repo agent. I took possession of this vehicle for not paying the mechanic. We got a mechanic lien title , I paid the mechanic , the car is now mine.
The car was over heating when I got it. I found the water pump leaking from under the pulley. I also found a hole in the rad right behind the fans. Changed them both as well as upper and lower hoses. New T-Stat. Flushed system and put HOAT in and air evac the system. When doing all this, the coolant temp sensor broke. Don't ask "father in law" so I changed it out. Cooling system runs great.
Car runs a little rough. Smokes a little. But was sitting for a few months without being started. Smoke clears up after its put in drive and driving for 5 min.
I do need to change the valve cover gaskets. Pass side is leaking a little in the back. And I plan to change out the plugs when I do this. My guess from the way this car was taken care of prior , it's got the original plugs. I will be going with coppers because I do plan on changing them again to see if there is any foul play.
I am pulling 5 trouble codes and would like to hear your thoughts.
0520: engine Oil pressure sensor circuit
0113: intake air temp sensor circuit high
0131: o2 sensor 1/1 circuit low
0038: o2 sensor 2/1 heater circuit high
0117: Engine coolant temp sensor circuit low
This car has no mods. It's stock as far as what I can see.
Thank you in advance for your thoughts and input.
