1 - 1 of 1 Posts
Trying to figure out what gears will be best in the long run. No it wont be 100% 1/4 mile vehicle. I build everything to be good overall. Meaning the vehicle is still full weight with a system in the back. I'm in the process of doing a 4.0l stroker build on my 2008 Supercharged Chrysler 300 with 3.5l and NAG1 swap already. BEFORE this engine rebuild I was sitting at 345RWHP, running a 14.15 @ 102MPH, 7.9PSI, 0-60 is 5.9s all with a canned tune. Also found out I was loosing the rest of my 10PSI out the back of the EGR upper intake port. Basically about to make my own stroker with this factory short block. The compression of the 3.5L is 9.9:1 to where the 4.0L is 10.1:1. I can't wait to see the results. Hoping for some where around 450RWHP. If achieved it should be around a 12 sec V6.... Going off the numbers anyways. Mods Im working with are as follows:
PREFORMANCE
o JBA Shorty Headers
o Custom Mandrel Bent True Dual Exhaust
o Straight Piped Convertors
o SRT 4 Injectors (577)
o 3-Bar Map Sensor
o Platinum NKG Spark Plugs
o Ported Throttle body
o True Cold Air Intake (Mounted in Bumper area)
o Custom FMIC (Front Mounted Intercooler) Setup
o Upgraded PowerDyne Supercharger
o Sur-Grip Coated Supercharger Pulley (dropped from 3" to 2.75")
o GT500 Belt Tensioner
o GT500 SuperCharger Idler Pulley
o Gates RPM Micro-V Belt
o Custom Transmission Oil Cooler Setup
o Dual BT Catch Can Setup
o 3.90 Gears
o 42RLE to NAG1 (W5A580) Transmission Swap
o FTI Performance ESRT8300 Stall Converter
o Inertia Motorsports 3.5l HO 1.2v Camshafts
o Inertia Motorsports 3.5l HO V6 Premium Big Valve Performance Heads
o Inertia Motorsports 3.5l HO V6 Ported Lower Intake
o Mopar Performance Transmission Contol Module
o 2008 4.0L Dodge Nitro Engine Block
SUSPENSION & HANDLING
o Billet Tech Strut Tower Cover
o Mopar Performance Sway Bars
o Mopar Performance Track Pack Suspension
o Mopar Performance Strut Tower Brace
o Pursuit Big Brake Conversion (14.3"/13.8" rotors. Dual Piston Calipers)
OK so my vehicle came with transmission 42RLE VLP with 3.64 gears. I swapped the 3.64 gears out to 3.90's while still having the 42RLE installed. I then did the 42RLE VLP to W5A580 (Nag1) swap but kept the 3.90 gears. SO I have 3.64's and 3.90s both open differentials. Im running 315/35R20's in the rears
14.15s @ 102mph was with the MTCM Installed so shift points were 6200. I've since installed a Transfomer Gen1 to change shift points to 6500. Now goin off of.... the following being my "control".
Gears: 3.90
Shift Point: 6200rpm
Shift Into 4th Gear @ 96.02 mph
With the coming extra power I doubt ill get about 110 mph so raising the shift points to 6500 is going to have me shifting right before I trap. Im trying to figure out what rear would be a good choice.
Gears: 3.90 (Stock 2.7L 42RLE rear) -- uses 198mm axles
Shift Point: 6500rpm
Shift Into 4th Gear @ 100.86 mph
Gears: 3.64 (Stock 3.5L 42RLE rear) -- uses 198mm axles
Shift Into 4th Gear @ 108.06 mph
Gears: 2.87 (Stock 3.5L W5a580 rear) -- uses 198mm axles
Shift Into 4th Gear @ 137.06 mph
Gears: 2.82 (Stock 5.7L NAG1 rear)
Shift Into 4th Gear @ 139.49 mph
Gears: 3.73 (GetRad)
Shift Into 4th Gear @ 105.46 mph
Gears: 3.92 (GetRad)
Shift Into 4th Gear @ 100.34 mph
Gears: 3.55 (Richmond)
Shift Into 4th Gear @ 110.8 mph
What I think I should go with.
Gears: 3.07 (AWD 5.7L) -- uses 198mm axles
Shift Into 4th Gear @ 128.13 mph
or
Gears: 3.06 (GetRad)
Shift Into 4th Gear @ 128.55 mph
What is your guys thoughts?? Am I overthinking it?
1 - 1 of 1 Posts
