OK. In the manual it says you can program up to 8 different keys. My question is what happens if you try to do more than 8. Would it still program it and then make the first one in the 1-8 invalid or will it just not program anymore?
Also, one site said if a key is programmed to a vehicle already, it cant be reprogrammed to a new vehicle. I bought 2 keys off ebay that i was going to use the electronics in to use for my car. Will they work? The numbers on the back are the same. Thanks
The question is why you would want more then 8 keys for your car? :D
lol, actually i wanted to find a way to test remotes. Take the chip out and put it in my key then program it to see if it works. ut i dont want to do it if after 8 keys you cant do it anymore.
