1 - 4 of 4 Posts
Gettin ready to replace the 13 pin transmission plug just wanted to make sure that on a 3.5l. Where itss labeled for dealer use only is where I replace the lost fluid?
The tranny has no dipstick,so you need a special dipstick to check the fluid or go to the dealer a have them check it.
Yes, the "dipstick" tube (with the little plug that says Dealer use only) is where you pour in the fluid.
Dave
If you can stash a pan underneath and manage to catch most of the fluid that gets away, you should be fine with just measuring that and putting the same amount back in. Not ideal, but if you don't have a Miller tool that should get you there.
1 - 4 of 4 Posts
