Yeah, as RitzRT said it's mainly when it's not at operating temperature/still cold.Thanks for the reply. Does it seem to ease up when the car has been driven for a while?
Thanks for the reply. Yes it’s definitely worst when the transmission is cold. Unbearable at times thinking the transmission is going to drop out. Once heats up it’s not at bad. As you said it’s not normal, is this something I should get check out or deal with? I have a 2016 which mean the 5 year power train just ended.. my luck! Thanks manIt's not really "normal," but it isn't uncommon either. I have experienced the same on my low mileage scatpack when the transmission is cold. It's only happened a few times though.
Best,
How many miles on it? You could always try changing the fluid/filter. Instructions to change it and some recommendations for fluids are in this thread:Thanks for the reply. Yes it’s definitely worst when the transmission is cold. Unbearable at times thinking the transmission is going to drop out. Once heats up it’s not at bad. As you said it’s not normal, is this something I should get check out or deal with? I have a 2016 which mean the 5 year power train just ended.. my luck! Thanks man
It has 40000. The 5 year PT I believe expired 2021 which means I should have gotten this checked out beforehand!How many miles on it? You could always try changing the fluid/filter. Instructions to change it and some recommendations for fluids are in this thread:
ZF 8 speed transmission fluid change
Hello Do I need to change ZF 8 speed transmission fluid , if yes on which distancewww.chargerforums.com
Ignore the flame throwing from the sales person who used to frequent these groups. Or you could just ask your dealer to do it and pay a lot more.
The youtube video is pretty helpful.
Best,
thank you for your response.Bjs:
What was your Charger's in service date? If it's late in the model year, you might have some PT warranty left. It would not hurt to look into it. If expired, but recently, sometimes they can do a goodwill repair.
Don
Thank you buddy. I’ll try that and see!Some other folks have reported success with disconnecting the battery for a while (5-10 mins) and then taking it for a spin when you reconnect the battery and it "re-learns". I haven't done that myself so just recalling what others had tried in the past.
Best,
taking into the shop on Monday I’ll keep you updated! Thanks for the replyMy 2019 R/T with under 8,500 miles has done this a few times, even when at full operating temperature. It also has this “slipping” type sensation when I take off from a dead stop. It’ll feel like it’s slipping then thump into 2nd. Not very pleased with this transmission
Taking it to the dealership on Monday the power train is good until July. So hopefully whatever is wrong will be covered.Turn the ignition on, then press the gas all the way to the floor, then turn the car off. Wait for 5 min, then turn it back on, this will reset the TCM. Also if you bought the car after todays date in 2016 you still have a warranty. Your warranty is 5 / 60,000 from the date and mileage at the time of purchase, the model year and mileage at sale has nothing to do with it. If you bought the car on June 23rd of 2016 with 437 miles on it you have a warranty until June 23rd of 2021 and 60,437 miles.
Edit: There are also a few reprograms they've done on this trans to smooth out shifting issues. You may just simply need to have it flashed to the newest version.
If a dealer avoids warranty work, avoid that dealer.I know warranty work some dealers don’t like doing.
Not sure there is one, but might have one for that symptom. Seems like thats always the first step. If it doesnt help, then your looking at a transmission because to my knowledge they dont have a replacement valve body. You might call a dealer and see whats availableSo what’s the update?
