I have a '07 Charger, 2.7l.
I've been towing my charger with a tow dolley over 500 miles and I had to put it into neutral to get the back wheels to turn in order to tow it.
In order to do that the keys had to be left in it. I didn't wanted to leave the car on and end up with a dead battery, so I tried to disconnect the red wire under the hood to get the power to go off. No luck.
I didn't want to unpack the whole trunk and disconnect from the battery so I just left the keys in with it turned only on Acc (car was not started) and car in neutral.
Got to my mid point, took keys out, went to bed.
In the morning I needed to readjust car on dolley, but of course the car is dead. Got a jump and tried to go into reverse and the trans would not shift (not a pink thingy problem). The shifter will move to all gears, but the car won't shift.
The gear indicator is completely lit-up (every light, see pic) until the car is shifted. Then the gear indicator stays in R--no matter the gear the shifter is in.
ALSO, there is an odd noise now when you try to apply gas to actually back up:
https://www.youtube.com/watch?v=sOM8IjsmnK4&feature=c4-overview&list=UUrZvUNh79pLjES8ATj-Orjg
Ignore the wind, listen to sound at end of clip.
CLIFFS:
Towing charger on dolley
Messed with battery/electrical
Trans won't even attempt to shift into gears
Odd noise now when applying gas
HELP!!
CLIFFS:
HELP!!
