1 - 2 of 2 Posts
2015 Dodge Charger SXT+ RWD
so I’m installing my brake rotors and pads as mentioned in previous post. I ran into trouble when it comes to re attaching the brake caliper bolts. I’m using lock tite and I need to know the torque specs for the bolts ASAP.
295619
295620
The front brake caliper bracket should be tightened to 70 ft/lbs and the rear should tightened 85 ft/lbs. The caliper bolts have a torque spec of 44 ft/lbs and 23 ft/lbs in the rear.
No locktite required.
Best,
1 - 2 of 2 Posts
