I'm looking at v6 models and I'm noticing that some of them come with 17in tires and some with 19in. I don't think that they'd add any horsepower or use a different transmission depending on those cars so I'm wondering if there's a major difference in performance do that?.
The car will run better with the smaller wheels, larger wheels reduce acceleration. Don't know about Charger but with Challenger you get a 3.07 gear in the car when you order 20's instead of the 2.62 you get with 18's to try to get some of that performance back.
As long as the overall diameter is not significantly different the only noticeable difference will be ride comfort.
A factory 18 inch wheel with a higher profile tire can be very similar in overall diameter as a 20 inch wheel with the normally smaller profile tire.
But the weight moves outward with a larger wheel so it acts heavier because of the rotational effect.
Not to a great degree but you could probably measure it.
And they don't do it on Charger but on Challenger, the SXT cars with 20's get the bigger R/T brakes for the same reason.
Also the only cars that have 19 inch wheels stock are AWD. All else being equal the smaller lighter wheel/tire will give you a bit better performance in a straight line but from a 17 to 18 or 20 isn't a huge difference. If you get really heavy 24s with big tires you can easily add +15-20 pounds at each corner and really sap your straightline performance.
