1 - 11 of 11 Posts
Just bought a new set of 22 inch rims and live in a area with no snow does anyone have a recommendation for a good all season tire/size that fits 22's?
Thanks
Huevosman
Thanks
Huevosman
I would go with an all season 265/35/22 size tire, if your looking to not spend too much and still get a decent tire go with some Kumhos or Cooper.
Thanks
Huevosman
I'm running Nitto 420's in a 265/35/22 and I'm VERY pleased. No road noise, the ride comfort is as good as the stock wheels. And what i like most is the wet traction and the dry traction. I would definitely purchase another set of these.
those Nitto 420s are a VERY good all around tire... we have had very good experiences with them and they have a very good tread life!
Supporting Vendor
Tire & Wheel Specialists
I have 265/35/22 in the front and I feel like the tires are to close to the strut area can someone help ?
The wheel dimensions play a roll in the overall fitment (I.E. rim width and offset).
Are the front tires touching any suspension components or rubbing anywhere? if not, you should be in good shape.
I have 265/35/22 front & rear on 9.5" width wheels. The wheel offset and backspacing will make a difference depending on the wheel design (I have Versante wheels). Like Discount Tire said, you're good if nothing is touching/rubbing. The bolt you see, close to the top of front tire, is the upper control arm that moves up/down with the tire. You should be able to slide your finger between the tire and this bolt (upper ball joint stud) ... which is plenty of clearance.
292605
1 - 11 of 11 Posts
