My brake lamp switch has been...difficult, mostly due to my efforts. Literally took it apart and put it back together, not convinced it's correctly assembled, may be 180° out of position.
Then the cruise control stopped working, and won't set.
Brake lights are working correctly
Now I'm throwing the code listed above, which is essentially a speed sensor.
Also painted the calipers and rotors. Painted the rotor hubs in areas not in contact with the wheels, or obviously braking surface.
Is there a sensor pickup on the calipers I shouldn't have painted?
Is there a sensor trigger on the rotor I shouldn't have painted?
Any suggestions on the brake lamp switch?
Any other ideas?
Any other ideas?
