1 - 2 of 2 Posts
I own a 2006 Charger SRT8 with the Navigation unit, Sirrus, U-Connect...
I am thinking about converting to a MyGig unit... But I have a few questions...
I know I would need the RER unit to keep all the functions, correct?
Also, I know the size difference between the 2 units... Is there a bezel that would fit or do I have to modify one to fit?
Do I have to purchase the U-Connect harness or can I jump the wires to work?
The RER is the one you want to keep NAV and bluetooth............the RER has the bluetooth built into it so you just need a mopar mic (better then the coastaltech mic) to plug into the back of it........you will also need the lockpick adapter from Coastaltech......you will need a sirius extension cable and terk splitter if you want to keep your station display on your dash
As far as the bezel goes, you have two options........you can take the standard radio bezel and cut it out larger to fit around the mygig (what I did), OR, you can use a nav bezel and have a stereo shop use ABS plastic to fill in the gaps around the radio (kind of like a dash kit)........08/09 bezel will not work
1 - 2 of 2 Posts
