2013 dodge charger purchased 3 weeks ago In my rear tail-light in the bottom left corner of the oval tail-light it appears that 2 or 3 of the consecutive bulbs went out...how do I fix or replace these?? Does the whole taillight have to be replaced?
If you have a taillight with a few LED's inop. then it is not a wiring issue. You need a new taillight.I had a moon roof installed a week ago, and I know for sure the tail light issue wasn't there before I dropped it off at the shop, do you think that could have caused an issue with the wiring for the tail light?
Yeah, that's the center taillight, $400 new.Could be, I don't see why just a couple would burn out and not the rest, I can't even find any sites that have the tail light itself for sale either...
I'd be super annoyed seeing that too!Could be, I don't see why just a couple would burn out and not the rest, I can't even find any sites that have the tail light itself for sale either...
Yes I've broken one open after replacing damn thing twice, these are on sealed, or printed circuit boards, I don't see how anyone would be able to replace subfloor leds, and its corrosion that shorts them out at the ends.Has anyone broke one open yet?
If more than 1 led is out then it's the board or resistors, should be a relatively easy fix. Hardest part would be opening and resealing the lens.
But yeah, should be under warranty.
Edit: there is no flex, hard to imagine how this would happen. Poor QC from supplier?
5 years late but, would you still be interested in trying to fix? I have one already cut open and the leds are on printed boards I think.If you do end up buying a new one send the broken one to me. I'm sure I can fix it in a day and send it back. Maybe you can return the new one. I'm a avionics guy and pretty good at this stuff.
Lol I don't think there's a tutorial. Just have to be experienced in fabrication. But if you'd like a custom set I just finished the prototype. Check out my videosHi,
how do you open up that tail light? Is there a tutorial somewhere?
thanks
I just want to play around myself and I won't be able to drive around with that here in Germany 😂Lol I don't think there's a tutorial. Just have to be experienced in fabrication. But if you'd like a custom set I just finished the prototype. Check out my videos
That's one video, my channel has others
Why would you not be able to have this in Germany?I just want to play around myself and I won't be able to drive around with that here in Germany 😂
It will most likely end up as decoration. So just wanted to check where and if to heat some parts.
