Hello everyone!
I have a 2006 5.7L Charger R/T, im looking to swap the intake manifold for a stock 6.4L. I've done some research already, but i'd like to get some some feedback on my specific situation. I've seen a few threads regarding this issue but all of them (as far as I have seen) have been about 2011+ models, so please be gentle if i'm breaking the rules or something...
I'm also planning to swap my 5.7 throttle body and CAI for 6.4 models. I have several questions so i'll make them brief;
1. First off, would installing a 6.4L intake on a 2006 5.7L work?? Is it just a bolt on or do I need additional parts? (like fuel rails, map sensor, etc.). Please be specific!
2. Would I be able to install a high performance (95mm - 103mm) throttle body to a stock 6.4 intake?
3. Since 6.4 chargers weren't around in 2006, would I be able to add a 6.4 CAI as well? Or would I need to settle for a 6.1 or even a 5.7?
4. Would I need to get it tuned afterward to drive properly? (not just to operate with the most performance)
Suggestions/links to parts would be highly appreciated!
Any tips on the coming swap would also be well received!
Thanks!
You would have to contact a shop like Modern Muscle Xtreme in Martinsville Va to see if they have an adaptor plate to fit the older models. From what I remember it is not a simple bolt on like the Eagle motors.
I'm afraid not. I talked to Modern muscle and was told the runners are in a different location so they will not work. Looked and 6.1 upgrade but would do it all fuel rails, injectors, throttle body and it's just too much for right now.
It' not a worthwhile swap on a pre-eagle, especially with the stock heads. Different story if you're retrofitting eagle heads and camming it. Then you just need the spacers, 392 air tube and rpm switch with pigtail.
